After months of wrestling with this Revmaster "RevFlow" carb I finally purchased an AeroInjector. After a few hours of adjusting it was ready to test fly. Bottom line - it works! Not balking, no hesitation, full 3200- static rpms. EGT's cool in flight.
Following are some pictures for the setup.
First off I needed to fabricate a cable reversal bell crank. I built it such that 3" pull on the control is 1.5" push on the aeroInjector. Sorry the pictures are so large, you'll have to click on them to see the full image.
- BellCran_b4_install.jpg (196.24 KiB) Viewed 6085 times
- BellCrank_Underside.jpg (117.77 KiB) Viewed 6085 times
The bellcrank base is made from 2" angle. The radius didn't quite fit the 1/2" Diameter engine mount tube but with some sanding it was not far off. Then the radius was liberally filled with RTV and loosely set in place to dry before tightening the hose clamps. The hose clamps are protected with Adel clamp rubber strips so as to not damage the mount.
With the engine off the control works smooth as butter but there is a bit of resistance felt when accelerating. Thinking this is normal as a sucking engine will pull that slide tight. It's not too much, just different.
Now onto the carb.....
