Oil filters on a VW anybody else installing one?
Re: Oil filters on a VW anybody else installing one?
Postby gammaxy » Fri Jan 02, 2015 10:40 pm
chuckster wrote:Slightly off topic, but I was not aware Bob Hoover had died. Google does not mention it. Does anyone know the date?.
There are at least two Bob Hoovers in aviation. The famous airshow and test pilot is still alive. The other Bob Hoover is well known for his work on VW engines. He passed away August 13, 2010.
Postby rizzz » Sat Jan 03, 2015 1:35 am
He used to start his blog with "No, not that Bob Hoover..."
You can find his blog here BTW. Awasome reading for anyone putting a VW on their aircraft:
http://bobhooversblog.blogspot.com.au/
Postby Mustang » Sun Jan 04, 2015 12:49 am
We have a Fram TG3614 on our AeroVee and it works just fine. N179ES Sonex
Mustang
Postby rizzz » Sun Jan 11, 2015 6:58 pm
Completed the oil system installation today.
I have a hose going from the pump cover plate to the oil filter along the right side and back side of the engine, then from there back to the oil cooler on the left side, then coming out of the right side of the cooler back to the engine where it was drilled and tapped for the oil return.
The hoses have been insulated with speedflow hose insulation material and the fittings have been wrapped with heat wrap tape.
Postby Gibbsfamily1 » Thu Apr 09, 2015 7:15 pm
All I can say is I did it and took it off. Just change the oil often and forget it.
Gibbsfamily1
Postby rizzz » Thu Apr 09, 2015 7:59 pm
Gibbsfamily1 wrote:All I can say is I did it and took it off. Just change the oil often and forget it.
Why did you decide to remove it again?
Was it causing problems or did you just not see the benefit?
Postby mike.smith » Thu Apr 09, 2015 10:15 pm
I only have 80 hours on my engine, but I've done 4 oil changes and sent in 4 samples for analysis. I've cleaned the screen 2 times. The last time there was only a few particles of carbon, and nothing else visible. The oil analysis are coming back fine. Accessing the screen is a pain, but so far the engine hasn't shown a need for a traditional filter. It would be nice not to have to get to that screen, though.
Postby wlarson861 » Fri Apr 10, 2015 1:58 am
No. Change oil every 25 hours so you can adjust the valves and avoid another single point of failure. Blew an oil cooler from high pressure and got intimate with a bean field, I think an oil filter can would have blown at a lower pressure than the cooler but I could be wrong. Had a cardinal with just an oil screen and 25 hour oil changes that didn't run out till 2600 hours. Filters are for constant speed props.
Bill Larson
N861SX
wlarson861
Postby Waiex 176 » Fri Apr 10, 2015 1:57 pm
I am flying with the Aerovee. I installed an oil filter. I thought it would help with cooling, I realized it increased the number of failure points in my system. I was pleased with the set up until one cold morning (26°F) after engine start oil pressure went to 0. (I had no means of preheating). I immediately shut down and found I had blown the gasket out of the top of the filter. I was using racing filters because I was told they were stronger and made to take more abuse. Luckily I had no damage to the engine, just a big mess to clean up. I will be removing the filter when I upgrade to the turbo. The turbo comes with a reusable internal oil filter. I can't speak to any differences in performance or cooling at this time. If I had it to do over I wouldn't install the external filter. I would consider the internal filter instead. Besides fewer points of failure, there would be some weight savings.
John ( N176WS)
Waiex 176
Postby Sonex1517 » Fri Apr 10, 2015 3:14 pm
Just to clarify, the turbo itself does not come with a filter. The conversion requires the new mini sump.
As part of the turbo kit a mini sump assembly with integral filter is included.
It is AeroConversions p/n ACV-P06-75 per my manual.
Chicagoland
N1517S reserved
Return to Other Engines
