LarryEWaiex121 wrote:My initial take on this is its promising for slow type airframes that are currently using Rotax's.
I'm a skeptic when it comes to a Sonex airframe. For the same reason the Rotax is a marginal install.
Gearing. This is using reduction instead of direct drive and turns to slow for our style of airframe with its broad speed range.
I don't see a Sonex using a 70" prop very successfully. I'd guess that's going to be about in the range of diameter this engine is going to be pared with. Maybe even a touch longer.
If I was building something along the lines of Highlander, I'd be looking hard at something like this.
Larry
Waiex 121, 416hrs. Jab 3300, solid
Users browsing this forum: No registered users and 23 guests
