RPM sensors
RPM sensors
Postby Nick » Thu Oct 05, 2023 6:30 pm
I have a MGL MX1 IEFIS. Can anyone explain how to get two RPM readings When doing the Mag Checks. I have one Electronic Mag and One of the original Jabiru 3300 came with. If I turn off the electronic Mag I lose the RPM so can't see any drop. I do have a new sensor on the tab pickup for RPM but not sure where to connect the wires? I was thinking I could tie it in with the RPM wire from the Electronic Mag. What has everyone else done. Thanks
Nick
Legacy Sonex Waiex 0179
Jabiru 3300 Gen1 Rotec WCH, EI, TBI
N908WX
Nick
Re: RPM sensors
Postby BRS » Fri Oct 06, 2023 11:21 am
I had an MX1 for awhile, until I got tired of waiting for them to fix their software. But I know exactly what you are asking and there is an easy solution - not sure if I remember it all. Basically you connect your RPM sources to RPM1 & RPM2. Then the MX1 will read the higher of the two. So when one drops out the other is the one being read. I don't recall what kind of setting (if any) need to be made in the setup.
So my MX1 was replaced with a Xtreme EMS which does not have this (above) feature. In order to see the two RPMs I had to configure it to show two RPM gauges. It's a bit of a compromise.
-Brock
Sonex-A (s/n 1013)
R2300, P-tip 54/50
Center Stick
V16, TT22
BRS
Re: RPM sensors
Postby sonex892. » Fri Oct 06, 2023 4:08 pm
If you have the small two wire Jabiru sender with a 1/4" thread? Black wire to ground, and red wire to one of the 2 rpm terminals on the RDAC. Will then need to select the correct dip switches and gain on the RDAC. If this is the sensor you have I can have a look at what I have selected on the RDAC. Also need to set up pulses per rpm on the display.
Once set up this tacho input works really well..
Lazair kit 1981 sold
Sonex kit 2010
Sonerai 2LS project rotax 912
sonex892.
Re: RPM sensors
Postby Nick » Sat Oct 07, 2023 11:56 am
Steve you are absolutely right. I am going to use one source the Jabiru sender and not worry about the Mag or EI because the sender will always send RPM. Don't know why I didn't think of it to begin with. Thanks to everyone for the Ideas. Nick
Nick
N908WX
Nick
Return to Jabiru
