Jabiru 3300A distributor Cap
Posted: Sun Apr 23, 2023 6:35 pm
I was working on my Waiex and Jabiru 3300A. I was making sure bolts and nuts were tight and doing a general wiring. While I was doing this I noticed that the distributor caps were loose so I started to tighten. I could not find any kind of indexing point on the distributor cap. I could turn or twist a couple degrees with the hold down screws. My question is this normal or do I have defective Caps. There has to be some kind of indexing or the timing could change. These are new distributor caps, but I still have the ones that I got with the motor and they are the same. AM I MISSING SOMETHING HERE? I bought the motor that sat for 10+ years and did a top end overhaul on it. So it has not run yet. Any advise Please, Thanks OH PS There was someone just the other day that came by and they have a 2200A and they checked theirs and there is an indentation where the hold down clamp indexes on their distributor cap.
