New sonex cooling baffles question
Sun Feb 05, 2023 12:50 pm
by Wood
Hey everyone. Hope you’re all doing well and 2023 is treating you good. Question? I recently purchased the cooling baffles from sonex for the Jabiru 2200 and put it together. Fits well but I’d like to paint it and was wondering if anyone had some suggestions on the type of heat resistant paint to use.
Thanks in advance.
Mark
Re: New sonex cooling baffles question
Sun Feb 05, 2023 4:54 pm
by pfhoeycfi
Wood wrote:Hey everyone. Hope you’re all doing well and 2023 is treating you good. Question? I recently purchased the cooling baffles from sonex for the Jabiru 2200 and put it together. Fits well but I’d like to paint it and was wondering if anyone had some suggestions on the type of heat resistant paint to use.
Thanks in advance.
Mark
I used rustoleum high temp grey for furnace & BBQ. So far so good....
Sun Feb 05, 2023 7:01 pm
by karmarepair
I would not think you'd need high temp paint, as the baffles should only see cooling air, but if you must, a quick maroon scotchbrite rub, a solvent wipe, and any locally available rattlecan high temp paint should do it. High Temp paint works best WITHOUT an underlying primer.
Mon Feb 06, 2023 12:56 pm
by Wood
Thank you guys for the replies. Very much appreciated
Mark
