New sonex cooling baffles question
Postby Wood » Sun Feb 05, 2023 12:50 pm
Hey everyone. Hope you’re all doing well and 2023 is treating you good. Question? I recently purchased the cooling baffles from sonex for the Jabiru 2200 and put it together. Fits well but I’d like to paint it and was wondering if anyone had some suggestions on the type of heat resistant paint to use.
Thanks in advance.
Mark
Lyncrest Airport - CJL5
Winnipeg, Manitoba
Sonex Legacy #0327
Jabiru 2200
Serial # 22A 1130
AeroConversions
Wood
Re: New sonex cooling baffles question
Postby pfhoeycfi » Sun Feb 05, 2023 4:54 pm
Wood wrote:Hey everyone. Hope you’re all doing well and 2023 is treating you good. Question? I recently purchased the cooling baffles from sonex for the Jabiru 2200 and put it together. Fits well but I’d like to paint it and was wondering if anyone had some suggestions on the type of heat resistant paint to use.
Thanks in advance.
Mark
I used rustoleum high temp grey for furnace & BBQ. So far so good....
Peter Hoey
Philadelphia Glider Council
Also built Sonerai IIL N86PH
pfhoeycfi
Postby karmarepair » Sun Feb 05, 2023 7:01 pm
I would not think you'd need high temp paint, as the baffles should only see cooling air, but if you must, a quick maroon scotchbrite rub, a solvent wipe, and any locally available rattlecan high temp paint should do it. High Temp paint works best WITHOUT an underlying primer.
karmarepair
Postby Wood » Mon Feb 06, 2023 12:56 pm
Thank you guys for the replies. Very much appreciated
Mark
Winnipeg, Manitoba
Sonex Legacy #0327
Jabiru 2200
Serial # 22A 1130
AeroConversions
Wood
Return to Jabiru
