I am connecting up the air system to the Bing Carb. I am using the stock Jabiru air filter box with integral carb heat diverter.
The manual says the air supply to the filtered air box needs to be connected to outside air, not from inside the cowling. I thought I have read that connecting to outside air could create uneven fuel/air distribution.
Where should the air supply be connected?
It certainly would be easiest to leave as is open to the air inside the cowling.
I have a manifold pressure sensor built into the GRT R66 EIS. I would like to connect it just because it is there. Is there an easy solution to connect to the induction system?
Rick Caldwell
Xenos 0057
- Air Filter Mounted Sm.jpg (171.11 KiB) Viewed 1761 times
