by DCASonex » Sat Aug 01, 2020 9:23 am
A couple of keys to cooling rear cylinders of a jab 3300 are:
Extend the back end of the plenums down to wrap around backside of cylinders. On #5 if using the fuel pump for a Bing, it should extend far enough to also shield the pump. An extension made of 60-61-T6 aluminum will flex enough to allow removal of the plenum. On #6, seal around the cutout for the engine mount.
Just as important as CHT, and perhaps more so on Jab and CAMit engines is airflow around the steel cylinders. Steel does not conduct heat anywhere near as well as aluminum, and the cylinders walls are thin. Hot spots can develop that cause the oil to break down and scoring results.
Keep the air moving. Baffles that disrupt the airflow may appear to help even out the CHTs but but they reduce the ram air effect that carries cooling air back to the rear cylinders. The plenum can be gradually reduced in cross section while moving to the rear, which helps force a bit more air down between cylinders. Take into account the fact that the incoming air will be spiraling, upward into cylinder #2 and down at cylinder #1. This tends throw air up and over #2, and ram it back to #6. Some folks have the problem where #2 runs hot and # 6 cold for this reason. It also robs the right bank of ram air to rear cylinder #5. Do what you can to smooth the flow.
To complicate matters, too much air running into a vertical wall such as at the back of the plenums can result in an unexpected result where the air is compressed, then rebounds making a pulsed stuttering like effect that reduces flow. I used to encounter this a lot when designing shrink tunnels for packaging, and the effect would be very difficult to observe in flight or even on the ground, Again, do what you can to smooth the flow.
Make sure all the air that comes in, goes through something to pick up heat before it exits. The inter-cylinder gull wing baffles that mount under and between cylinders can be made slightly larger and bent to fit up between the cylinders a bit further.
Just had cataract surgery and hard to see computer, hope not too many typos in this.
