by tx_swordguy » Fri Nov 16, 2018 7:01 pm
Don't know the reason for it being different from the manual, however if the former and the new rings are both square than I wouldn't worry about it. I just got new rings for a 3300 solid lifter and one ring appeared square with no markings and one appeared square with a dot punched in one side. upon closer (much closer) examination I noticed a slight angled exterior side of the ring that is actually angled to scrape oil back toward the crankcase. The dot must be installed toward the top of the piston I believe. The unmarked ring from my understanding is truly square and it does not matter which side is up.
Mark Whiddon
T25 Aero Estates
Sonex N889AP
jabiru 3300 solid lifter
