by sonex892. » Tue Jul 17, 2018 9:16 pm
You don't use gravity to test fuel flow when the Jabiru mechanical pump is used.
You will need to use the mechanical pump for your test. Spin the motor with the spark plugs removed for a timed period say 10 or 20 seconds then calculate the flow from that. Then the same for the electric pump, if you have one.
Sonex 892
Lazair kit 1981 sold
Sonex kit 2010
Sonerai 2LS project rotax 912
