by Rick524 » Sat Jun 30, 2018 7:23 pm
Hi Steve, thanks for the reply. I removed the float bowl and held the float up, while my wife
cranked the engine over. No gas pumped out until I let the float drop. I removed the carb from the engine for a closer look. I put a hose on the gas nipple and blew while cycling the float up and down. All good.
I tweaked the float down slightly and re-assembled. Then I connected the fuel line to the carb and while
I held it, my wife cranked the engine......no leaks.
I re-installed the carb and will try it tomorrow. Sure hope it works, everything smells like gas around
here, including me.
Rick
Sonex 524
