My Jabiru 3300 failed a mag check on my last flight's run-up. The engine ran fine, but one mag was completely in-op. Troubleshooting the problem I determined that the problem was within the magnetron ignition coil unit, and not the starter switch, mag wiring, spark plugs, spark plug wires, distributor cap or rotor. My engine is a late-model roller-cam engine, with 300 hours on it.
Removing the coil allowed me to see the problem clearly. The distributor wire had broken at the connection to the coil housing. The distributor wire exits the housing at a molded shoulder. This stabilizes the wire and prevents it from disconnecting from the coil innards. The wire also has a built-in strain relief rubber boot, but the boot also connects to the shoulder. This places all the load from any vibration in the wire at the junction of the body and the shoulder, and that's exactly where the failure occurred.
Jabiru uses an ignition coil sourced from a Honda generator, but these coils are similar to many tractor and other small engine ignition coils. It is possible to buy similar coils off eBay or other suppliers, but with so many imitation parts out on the market, there's no telling which are genuine. There are several anecdotal stories of imitation Honda coils being used on Jabiru engines, only to fail in short order. I ordered an authentic coil from Jabiru USA, just to be safe.
To prevent this type of failure from happening again, I will stabilize the distributor wire to prevent vibration from working on that shoulder. I suggest inspecting these junctions periodically to look for signs of cracking, and excessive movement in the distributor wire likely indicates a crack has already occurred.
Jeff
