by DCASonex » Wed Dec 06, 2017 9:24 am
To lift Jabiru engine, best to first remove the prop for its protection, then just thread a rope under the cylinder barrels each side and use common engine hoist, it balances pretty well that way. I purchased the Sonex bushings, way back ?? but have only used the softer Jabiru ones preferring the slightly better isolation. If it sags after a while, quick fix is to place a single spacer washers on the exposed forward end of upper bushings and re-tighten. The added compression of the bushings will move that point of engine back about 1/2 the thickness of the washer. When doing that, no need for engine hoist, just remember to remove nut from only one bolt at a time.
