Ellison Carb
Ellison Carb
Postby vhhomer » Thu Aug 24, 2017 1:01 am
Does anyone out there have experience with Ellison carbs. I have an EFS-3A on my Jab 3300 and for the second time it has suddenly started running overly rich and drizzles gas when I shut down. The first time it did this I sent it back to Ellison Fluid Systems and they reported that the diaphragm had a hole in it. The cost of that repair was astounding. This time I took off the back plate and the diaphragm seems to be OK. I couldn't find anything else obviously wrong. Anyone have any suggestions other than get a Bing/Aerocarb, etc.? Ellison is non-responsive on the phone and email.
Vince Homer
vhhomer
Re: Ellison Carb
Postby WaiexN143NM » Thu Aug 24, 2017 5:56 am
Hi vince,
I believe ellision went out of business a few years ago. I dont know if anyone is repairing them. I would reccomend the bing or rotec -40S. Tbi. Mark 2.
Re: Ellison Carb
Postby Fastcapy » Thu Aug 24, 2017 12:59 pm
I am not familiar with the Ellison as much as the Rotec but they are very similar.
If the diaphragm and regulator valve are similar between the two, which I fell is the case, it could be one of these 2 things.
1. The spring that pushes on the valve is squished down and isn't putting enough force on the valve to completely close it.
2. The valve o-ring, if free floating, may have shifted out of place and needs to be re-seated. I know Rotec redesigned the valve/o-ring assembly for this very reason.
Mike Beck
Oshkosh, WI (KOSH)
Sonex #1145 N920MB
Fastcapy
Re: Ellison Carb
Postby vhhomer » Fri Aug 25, 2017 12:36 am
Thanks for the suggestions. I checked the spring and it seems OK. Tomorrow I'll check the O-ring.
Ellison Fluid Systems overhauled the carb for me about 15 months ago so they were in business then. They still have a web site, email and phone number, but don't answer any queries.
I have a Rotec on my Jab 3300 in the Onex and it runs better than the Ellison. Does anyone know how much a Rotec costs?
Vince Homer
vhhomer
Re: Ellison Carb
Postby Fastcapy » Fri Aug 25, 2017 8:36 am
I believe they are up to $900 now for the MkII. They run show specials at Sun n Fun and Airventure normally like $100 off and free shipping.
If you want to save on shipping, Brian Kelly from Radial Conversions in Florida is now a Rotec dealer for the U.S. However, I talked with Paul from Rotec earlier this week and Brian has very limited stock of TBI stuff at this time and they are working on getting him all set-up with parts and complete units. So if you can wait a bit your best bet would be to wait until a show or until Brian gets running at 100%.
Mike Beck
Oshkosh, WI (KOSH)
Sonex #1145 N920MB
Fastcapy
Re: Ellison Carb
Postby wolfpack3 » Sat Aug 26, 2017 9:55 am
I have a Mk I that is in new condition and only used 5 hours for sale for $450 plus S/H.
Onex
Aerovee
wolfpack3
Re: Ellison Carb
Postby rhw5548 » Fri Sep 01, 2017 11:51 am
I have a Zero time BING available (760-207-2770) if interested.
Plans Built SN #0243
MGL EFIS Electronics
Tri-Gear, Dual Controls
Todd's Canopy
Prince p-Tip Prop
Echo UAT (ASDB)
Jab 3300 A
FlyQ EFB
rhw5548
Return to Jabiru
