K&N Air Filters for Jabiru w/AeroInjector
Postby sonex1374 » Fri Aug 11, 2017 11:01 am
Edit: The original numbers were quite wrong! The correct numbers are now below.
Cross posting this here for future reference.
I researched several K&N filters when I was selecting my Jabiru 3300 filter. According to K&N's calculator, the Jabiru 3300 needs 32 sq inches of filter area for 200 cu in displacement at 3300 rpm. I use the RU-0630, and it just fits between the AeroInjector and the engine mount tubing (tail dragger). It's oversized, but it has been working great!
My full results are below.
All these filters will clamp right onto the 2.25" diameter bell mouth of an Aerocarb or AeroInjector using the included hose clamp.
Filter # / Dia (in) / Height (in) / Effective Area (sq in) / Notes
RC-1950 / 4.5 / 2 / 24 / Chrome top
RC-0650 / 5.5 / 2.5 / 37 / Large and round; chrome top
RU-0650 / 5.5 / 2.5 / 37 / Large and round; 3/4" Off-center Flange
RU-0660 / 5.5 / 3 / 45 / Large and round; taller than 0650; 3/4" Off-center Flange
RU-0630 / 4.5 / 4 / 47 / Tall and skinny; centered opening
RB-0600 / 3.5 / 4 / 35 / Tall and skinny; 5 Deg Offset Flange Angle
RU-1710 / 3.5 / 5 / 43 / Tall and skinny; 20 Deg Offset Flange Angle
E-3120 / 4 /2 / 20 / Direct size replacement for the Sonex paper filter element
Jeff
Jeff Shultz
Sonex TD, 3300, AeroInjector
Kansas City, MO
http://www.sonex604.com
sonex1374
Re: K&N Air Filters for Jabiru w/AeroInjector
Postby rhw5548 » Fri Sep 01, 2017 11:47 am
Jeff
Do you know if these filters will work on both type of Engine Mounts? (Tri-Gear and conventional)
Plans Built SN #0243
MGL EFIS Electronics
Tri-Gear, Dual Controls
Todd's Canopy
Prince p-Tip Prop
Echo UAT (ASDB)
Jab 3300 A
FlyQ EFB
rhw5548
Return to Jabiru
