Propeller free Sonex...
PostPosted: Wed Jul 26, 2017 1:28 pm
by rbarber
All,
As many of you know already, I had my propeller fly off near Sioux Falls, SD. In hopes of saving someone some grief, the attached file is a short write up of the incident, as well as some analysis of the failure.
Regards,
R.
Robert E Barber
N157SX-Sexy Hexy
Propeller loss on a Sonex.pdf
(792.1 KiB) Downloaded 714 times
Re: Propeller free Sonex...
PostPosted: Wed Jul 26, 2017 10:07 pm
by builderflyer
Oh no.......a new reason to worry! Very glad you got it down safely, Robert.
Art,,,,,,,,,,,,,Sonex taildragger #95,,,,,,,,,,,,,,,Jab 3300 #261
PostPosted: Wed Jul 26, 2017 10:18 pm
by kevinh
Great write-up and very useful and wise.
PostPosted: Thu Jul 27, 2017 7:06 am
by Jim B
Robert
Thanks for sharing your incident.
Jim
PostPosted: Thu Jul 27, 2017 8:00 am
by lpaaruule
Thanks for the info.
I'm not sure that there is anything actionable I should do though. My prob flange cap screws were installed with loctite 620. Replacing them at some time interval might risk twisting the heads off.
I'll have to think about this.
PostPosted: Fri Jul 28, 2017 7:16 pm
by x3 skier
Thanks for the write up. One thing comes to be mind, which probably highly unlikely, is the use of some lower quality bolts. As an old accident investigator, that would be one thing I would require to be checked. If you can get an analysis of the bolt material, it would be well worth while.
Cheers
PostPosted: Sun Jul 30, 2017 12:14 am
by peter anson
Hi Robert, great job getting it down safely. I've got the brains trust thinking about this problem but I suspect your idea of changing the bolts every few hundred hours is the only practical solution. The parts manual specifies plain washers under the bolts. It might be better to use a couple of Belleville spring washers to prevent the bolts from loosening. Looks like a prop removal is in my future.
PostPosted: Sun Jul 30, 2017 3:00 pm
by kevinh
x3 skier wrote:Thanks for the write up. One thing comes to be mind, which probably highly unlikely, is the use of some lower quality bolts. As an old accident investigator, that would be one thing I would require to be checked. If you can get an analysis of the bolt material, it would be well worth while.
Yah - I'm not anywhere close to being a ME, but that is a very interesting theory.
