New Jabiru Manuals with Nordloc Washer Flyweel Issue Fix!
Posted: Mon Jul 11, 2016 3:14 pm
Jabiru has finally come out with fix to the flywheel cap screw issue, the use of Nordloc washers is approved!
Still required is a 100 hour torque check on the cap screws, however.
New maintenance manual
http://jabiru.net.au/Manuals/Engine/JEM0002-7.pdf
New Overhaul manual with change procedure
http://jabiru.net.au/Manuals/Engine/JEM ... Manual.pdf
