3300 static rpm; jabiru group?
Tue Apr 19, 2016 12:19 pm
by messydeer
Hey, guys :-)
I'd like to know what the normal max rpm for a static ground runup for a 3300 is. I've got a Prince prop, fwiw. And what are you getting in flight for WOT?
Last question, where is there now a Jabiru group? Yahoo is down, usjabiru.net site says it's under construction.
Thanks!
Re: 3300 static rpm; jabiru group?
Tue Apr 19, 2016 1:36 pm
by fastj22
At 6900MSL, my ground run up gets around 2700 RPM. In cruise, WOT at 8500 MSL I usually see around 3000RPM. Prince Ptip.
usjabiru.net changed to
http://www.jabiruna.com/forum/
Tue Apr 19, 2016 1:37 pm
by chris
Feel free to use the Jabiru section on our site
here.
I did find the following after a google search:
Jabiru Owners GroupJabiru Camit Yahoo Group
Thu Apr 21, 2016 9:53 am
by vwglenn
I saw 2900RPM static yesterday. The accuracy or my MGL RPM is suspect though. Plane runs a Sensenich prop.
Sun Apr 24, 2016 8:26 am
by peter anson
I used to run a 54 x 60 Prince P tip with carbon fibre coating. Full throttle static - 3000 rpm, full throttle straight and level - over 3300 rpm. Tach checked against optical tacho and is accurate. I measured the pitch of the prop and as near as I could measure, the pitch appeared to be a max of 59" rather than 60". Have since changed to a coarser pitch prop which is more suitable for cruise. What are you hoping to find out or achieve?
