2200
2200
Postby lgsievila » Fri Feb 19, 2016 1:37 am
Loren Sievila
Conventional Gear Onex33
CAMit 2200
Dynon Skyview
lgsievila
Re: Jabiru 2200 or Camit 2200
Postby peter anson » Fri Feb 19, 2016 5:22 am
The obvious problem is getting the weight and balance right. You'd have to build an engine mount so could shift the engine forward a bit which means mods to the cowling. I'd guess that difficulties would multiply. If you're going to all that trouble why not go for broke and fit a 3300?
Sonex 894
Postby lgsievila » Fri Feb 19, 2016 12:18 pm
I know the engine will have to move forward with a new engine mount and cowl mods are needed. Why not go for broke?? Because I already have a Camit 2200 in my shop that was going to be put on another project but I am so unhappy with the constant problems with the AeroVee that I am giving up on trying to "fix it".
The Onex is a great design and certainly a lot of fun to fly but that fun is substantially reduced waiting for the next hiccup from the AeroVee.
Thanks for your input Peter
Loren
Loren Sievila
CAMit 2200
Dynon Skyview
lgsievila
Postby fastj22 » Fri Feb 19, 2016 1:57 pm
lgsievila wrote:Has anyone put a Jab or Camit 2200 in a Onex. I know of one in Florida.
Loren
Could that Florida Onex be this one on barnstormers?
http://www.barnstormers.com/classified_ ... _Onex.html
Postby lgsievila » Sat Feb 20, 2016 1:44 am
That is the guy's name John that I saw pictures of with his Onex. Earlier ad said he was selling his Sonex because he was having too much fun flying his Onex.
Loren
Loren Sievila
CAMit 2200
Dynon Skyview
lgsievila
Postby peter anson » Sat Feb 20, 2016 5:17 am
Hi Loren, if you are going with the Camit 2200, can I suggest you stick with the Bing Carburettor. They work really well. Sure, you have to make a carb heat system, but if you are capable of making the engine mount, a heat system is easy. I wasn't aware that there was such a thing as a "Sonex burp" until I read about it here.
Sonex 894
Postby DCASonex » Sat Feb 20, 2016 9:29 am
Do not know if it would be much different with a 2200 engine, but on my 3300 installation, with air filter directly on the Bing Carb, it takes in air that has been heated by passing through the engine's cooling fins, and thus is much like flying with carb heat on all the time. Have carb temperature monitor and the electric heating option on the Bing, but have seen no real need for the electric heat. Would be a bit more power if taking in cold outside air, but at loss of simplicity.
David A. Sonex TD, CAMit 3300.
Postby lgsievila » Sat Feb 20, 2016 11:20 am
[quote="peter anson"]Hi Loren, if you are going with the Camit 2200, can I suggest you stick with the Bing Carburettor.
Thanks Peter-I already went through an Aeroinjector, a MK I Rotec, and MK II Rotec on the AeroVee so I will definitely be staying with the Bing.
Loren
Loren Sievila
CAMit 2200
Dynon Skyview
lgsievila
Postby lgsievila » Sat Feb 20, 2016 11:26 am
DCASonex wrote:Do not know if it would be much different with a 2200 engine, but on my 3300 installation, with air filter directly on the Bing Carb, it takes in air that has been heated by passing through the engine's cooling fins, and thus is much like flying with carb heat on all the time. Have carb temperature monitor and the electric heating option on the Bing, but have seen no real need for the electric heat. Would be a bit more power if taking in cold outside air, but at loss of simplicity.
Onex with 2200 should be pretty much the same as your David. A friend has a 2200 Jab in his Quickair with electric heat on the carb and it works great. I'll let everyone know how things work out.
Thanks for everyone's comments.
Loren
Loren Sievila
CAMit 2200
Dynon Skyview
lgsievila
Postby david.2.wilcox » Sun Feb 21, 2016 11:20 am
I agree with Peter's advice on the 2200. Intaking heated air is simply throwing power away. Although with the Bing it is important not to use ram air.
I have modified the Bing installation in three ways:
- The intake system receives outside air from a port in the cowling sidewall.
- Installed a 30 watt motorcycle carb heater element, Yamaha part number 3BT-83790-00-00, on to the empty Bing throttle mount.
- Installed a HACman mixture controll system, but using a miniture venturi as the vacuum source instead of manifold pressure. This allows leaning with wot and lean of peak operation. EGT distribution seems to be best at wot. My cruise EGTs are about 1300 at 7500', 2950 rpm, 2.9 gph. The venturi was made on a 3d printer if anyone wants a copy of it.
peter anson wrote:Hi Loren, if you are going with the Camit 2200, can I suggest you stick with the Bing Carburettor. They work really well. Sure, you have to make a carb heat system, but if you are capable of making the engine mount, a heat system is easy. I wasn't aware that there was such a thing as a "Sonex burp" until I read about it here.
Sonex 894
david.2.wilcox
Return to Jabiru
Users browsing this forum: No registered users and 58 guests
