Exhaust heat on intake pipes and oil lines 3300
Postby kmwoody » Sat Jan 09, 2016 6:30 pm
I showed my local A&P my install so far and he was concerned about the close distance between the exhaust pipes and the intake pipes and oil cooler lines. The #2 exhaust pipe was less than an 1/8" away from the intake. We were able to bend to 1/4" and he was happy with that.
I am thinking of riveting a deflector plate to the oil cooler, as David A. has done, or wrap the exhaust pipes for 6 to 8" from the EGT sensors down. I would wrap them equally in length to keep the EGT readings consistent. I am also putting Firesleve on the oil lines.
Are these logical ideas or totally unnecessary? I am thinking long term, keeping the heat away from the oil lines and intake joiners.
With the Inhibitor kit I am hoping the CAMit will make it to at least 1000 hrs. until any internal engine work.
Ken W
Sonex 959
Wishful thinking
kmwoody
Re: Exhaust heat on intake pipes and oil lines 3300
Postby fastj22 » Sat Jan 09, 2016 9:53 pm
If you wrap your exhaust pipes, it will reduce the radiant heat dramatically. I think fire sleave on the oil lines is unnecessary. Just my 2 cents and worth every penny.
Postby DCASonex » Sun Jan 10, 2016 10:26 am
Ken,
If you add that baffle bolt it on with a couple of small (#6) screws and lock nuts. Easier to install and remove oil cooler baffle that way.
Postby kmwoody » Sun Jan 10, 2016 7:39 pm
Thanks for the replies.
David, that does sound like a better idea than riveting.
Ken W
kmwoody
Return to Jabiru
Users browsing this forum: No registered users and 52 guests
