Continental and Lycoming have lots of ADs too. What you want is a company that tracks and publishes them. The information is available from the Jabiru website. Here is the NZ SB which adds a 500 hour replacement on top of Jabiru's SB. All supported aircraft and engines have SBs or ADs, as amateur builders it is our job to track them and perform proper maintenance. Fly safe and have fun.
Jim w0162 TD 3300
www.caa.govt.nz/Airworthiness_Directives/JABENG.pdfEngine Service Bulletins and Advisory Notices from Jabiru
http://jabiru.net.au/service-bulletinsJSB022-2 Propeller Flange Attachment June 20 2014
JSB031-2 Jabiru Engine Through Bolts September 10 2013
JSL009-1 Starter Solenoid June 5 2013
JSL008-1 Valve Spring Washer Adverse Wear Dec 21 2012
JSB033-1 Piston Circlips Aug 17, 2012
JSL007-4 Alcohol Lead Compression Ratio Fuel Guidance Dec 6 2011
JSB014-2 Propeller Installation Maintenance June 9 2011
JSB031-1 Jabiru Engine Through Bolts & JSD031-1 Service Directive April 14 2011
AVDALSR071-2 Through Bolt & 12 Point Cylinder Base Nut Installation August 9 2011
AVDALSR050-1 Procedure Engine Through-Bolt Nut Installation June 25 2008
Note: We recommend that operaters reading JSB031-1 should also read AVDALSR071-1 and AVDALSR050-1
JSB012-2 Jabiru Engine Flywheel Attachment Dec 22, 2010
JSB018-2 Jabiru Engine Tuning May 7, 2009
JSB021-1 Configuration Update 1 J160-C Jan 14, 2009
JSL005-1 Starter Motor Earth Cable September 1, 2008
JSB022-1 Propeller Flange Attachment July 28, 2008
Dipstick Settings & Comparisons April 4, 2008
JSB010-3 Statement of Compliance to ASTM LSA Feb 20, 2008
JSL004-1 Engine Cooling J230 Jan 29, 2008
JSL002-3 Engine Economy Tuning Cancellation of Service Bulletin Letter Oct 5, 2007
JSB016-1 Engine Cooling Apr 19, 2007
JSB013-1 Engine Rocker Chamber Vent Aug 8, 2006
JSL003-1 Fuel Tank Sealant Mar 11, 2005
JSB004-3 Jabiru_Engine Oil Pump 31 Mar, 2005
JBS005-1 Jabiru 6 Cylinder Engine Muffler Oct 10, 2004
JSB001-1 Revised Jabiru Engine TBO's May 11, 2004
Oil Cooler Mounting Instructions Aug 15, 2001
JSBA3 Fuel Systems Cleaning Jan 25, 2000
