High Oil Temps
High Oil Temps
Postby sonex293 » Sat Jun 04, 2011 8:39 pm
Just as a reminder.....
Don't over fill the Jabiru engines with oil. You will be greeted by high oil temperatures. I almost messed myself on my first flight after an oil change when my Oil Temps started to climb getting close to 240F....... On investigation after landing, I found two problems....First I had about 1/2 quart too much oil......not sure how that happened, and I also found a baffle that was moving out of place when the cowl was installed. Fixed both of those and my oil temp problems have vanished.
Just a FYI!
Michael Crowder
Sonex N293SX
Michael Crowder
ex- Sonex N293SX
Current - Just Highlander N371EM
sonex293
Re: High Oil Temps
Postby N111YX » Sat Jun 04, 2011 9:43 pm
Yep, I have found that about 3.2 quarts of oil after a change brings it into the magic "lower 1/3rd" range on the dipstick...
Kip
Jabiru 3300 #1637 and #3035
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Re: High Oil Temps
Postby Wood » Sun Sep 01, 2024 9:18 am
Yup that’s what I thought. Does take much either. Just did my annual and during the maintenance test flight after that found my oil temps increased to 220. Never done that before and suspected that I filled the oily to much. Need to drain some oil.
Thanks for posting this thread as a reminder
Mark
Lyncrest Airport - CJL5
Winnipeg, Manitoba
Sonex Legacy #0327
Jabiru 2200
Serial # 22A 1130
AeroConversions
Wood
Return to Jabiru
