142YX wrote:fastj22 wrote:I set mixture about ½ way for takeoff. Anything richer and it runs like crap.
John, Can you confirm your full rich position is at the full rich of the TBI's capability? (so when you say 1/2 mixture.. you mean 1/2 on the TBI itself?) If not.. where (approximately) do you set your full rich cockpit stop relative to the TBI's stop?fastj22 wrote:10 GPH on climb out at WOT with EGTs in the 1200s (much more than I saw with the Aerocarb)
I see 5 and 6 going a bit lean at WOT and pulling back throttle a bit brings them even with the others. (over carbing?)fastj22 wrote:I had intended to install a boost fuel pump, but decided to try with just the gravity feed. Its working fine with gravity only.fastj22 wrote:Just put another 2 hours on mine. I recently recalibrated my fuel system and found I was getting 25 GPH through the fuel feed disconnected from the carb.
You get 25 GPH fuel flow with your gravity feed system and no pumps (the engine driven pump is not installed in your setup also.. correct?)??! Very impressive. You quoted some in-flight fuel flow numbers.. do you have a fuel flow transducer? what kind? Was it in the flow path for your hanger calibration? If i could have gotten those kinds of flows, i never would have installed the pumps. Although, per Rotec, it shouldn't make a difference...
I must say i am jealous.. the performance you are getting is absolutely what i was hoping for!
Hi Nick sorry for the late reply, this time of year here is extremely hectic!
The first test I would do would be to make sure the TBI metering regulator is not passing fuel when the engine is off.
To do this depress the fuel primer button located in the center of the TBI regulator cover, with the throttle wide open and fuel pump on the fuel should pour out. When you let go the primer button the fuel should stop, may be a few drips here and there but should stop fairly quickly.
If after you let go the primmer button fuel continues to flow liberally then the regulator is not shutting off and may need attention.
I can send you out a refined flow valve we have been working on.
Also to get a nice clean idle you may need to adjust the small Allen screw located on the side of the TBI, this set the idle mixture only.
Also air inlet is extremely important, a good base line would be to ground run the engine with the filter and or ducts disconnected. Just for a quick test.
The reg spring length wont matter.
I would advise you send the TBI back to us and lets take a look and see why its so rich.
I suspect it’s a metering problem.
We will take care of it.
Please print a copy of this email and include it with the TBI.
onex28 wrote:I need to find a 90 degree female 1/4 NPT to 6AN male for a fuel line connection, preferably AL. So far the only thing I've found is a metal male 1/4NPT to female 1/4 NPT swivel hydraulic hose adapter, (internal pipe swivel adapter) which I could use. It has a 5000 PSI rating. Anyone have a source for an Al fitting? Just assuming that a hydraulic fitting would also work on a fuel line. Am I wrong?
David W
