WaiexN143NM wrote:Hi Nick,
Interesting reading , please keep updating on your trouble shooting.
John gillis and myself running gravity feed only on our jab 3300 w rotec carb waiex's. No trouble with ours. Nick and jake, are u running a pressure (facet pump) inline?
We set our slide to be fully open at a WOT. Ground static is 3000RPM, a little more in the air. I believe the VW carb install is horizontal, the jab is installed vertical.
The spring is small in the regulator. Stretch it 2.5 mm to the max of 17.
Also how are u venting your tank? We originally had a small length tube coming up vertically and bent into slip stream. Changed before first flight to a brake line picked up at Kragen/O'Rielly Auto to go down to bottom of cowl , and bent into slip stream. Small relief hole on back side in case bug etc were to hit and plug up opening. We didn't want any fuel misting out of vent to get on the lexan windscreen. Nick have you checked your vent tube ? Your plane sat for awhile awaiting your rotec, did u have your vent capped? Make sure no bugs tried to build a home.
SonexN76ET wrote:1) if you have your idle mixture too rich, your left side cylinders will run much richer than your right side. This is due to the idle jet being over on the left side of the TBI if aligned with the slide running fore and aft to the direction of flight. On my Aerovee it is a difference of over 120 degrees in EGT.
SonexN76ET wrote:2) on my last two flights (including one this evening) when attempting to do touch and goes when I advanced the throttle to full power for takeoff I lost all power and had to pull the throttle to idle and abort the takeoff. Not fun!!! The engine did not stall and did not surge or hesitate. I advanced the throttle very slowly. It seemed to happen after I was airborne and as I was passing 3/4 throttle. I am trying to figure out how to correct this. I am considering restricting the throttle full open position to see if that fixes it. Today's flight I tried a richer idle mixture setting and that did not solve the problem so I will be leaning my idle mixture a bit to get more balanced EGTs once again. I have cold air induction and will also try touch and goes with alternate air selected to see if that helps perhaps by eliminating rapidly changing air pressure at the same time of increasing throttle.
fastj22 wrote:I set mixture about ½ way for takeoff. Anything richer and it runs like crap.
fastj22 wrote:10 GPH on climb out at WOT with EGTs in the 1200s (much more than I saw with the Aerocarb)
I see 5 and 6 going a bit lean at WOT and pulling back throttle a bit brings them even with the others. (over carbing?)
fastj22 wrote:I had intended to install a boost fuel pump, but decided to try with just the gravity feed. Its working fine with gravity only.
fastj22 wrote:Just put another 2 hours on mine. I recently recalibrated my fuel system and found I was getting 25 GPH through the fuel feed disconnected from the carb.
