fastj22 wrote:vwglenn wrote:peter anson wrote:The MGL instructions for the RDAC suggest using the same connection as for a Bendix magneto - connect from the low tension side of one of the coils to the RDAC tacho input via a 10K resistor and remove the ballast resistor link. I actually used a 12K resistor, presumably because that was what I had available at the time. It works perfectly, completely reliable. I have checked it against an optical tacho and it is accurate to the resolution of the optical tacho.
Sonex 894
So essentially you just installed an in-line 12k resistor on the wire and are having success? Don't remember reading about that in the manual but I probably blew over the Bendix mag part.
I just reread the RDACXF manual on this and it seems pretty simple. I've never gotten a good reading from the alternator across the whole range.
Not familiar with the "low tension side" term, but it seems you just connect were the p-lead is. Will be experimenting myself with this.
fastj22 wrote:Update,
Put a 10K Ohm resistor on a wire from the p-lead to the RDAC and turned off the ballast and on the high gain. The RPM is solid throughout the range. No goofy readings like it did off the alternator.
