I also cut the connector off and went through a terminal block. It would be interesting to know how many failures occurred on regulators where people used a spade connector instead of a terminal block. As a side note I have a Kubota tractor with over 1400 hours on it that has the exact same regulator that is on my plane.As a footnote, I also use a terminal block for the alternator leads, instead of going through the connector to prevent issues with the spade connectors overheating.
tonyr wrote:I have replaced 2 regulators in 220hrs
The unit is mounted high on the fiirewall alongside the filler neck, but has no external cooling air supplied to it.
