Re: Prince P Tip
Postby N111YX » Sun Dec 21, 2014 10:05 pm
I liked my Sensenich but I love my Prince because it does not peel paint in the rain.
Kip
Jabiru 3300 #1637 and #3035
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Re: Prince P Tip
Postby fastj22 » Sun Dec 21, 2014 10:38 pm
N111YX wrote:I liked my Sensenich but I love my Prince because it does not peel paint in the rain.
I'll back that up. On our return from OSH i had the chance to fly my Waiex through 100 miles of rain at the end of our trip. I was convinced I trashed the prop. But the only thing I found was all the bugs were washed off and the prop was clean as new.
Re: Prince P Tip
Postby gammaxy » Sun Dec 21, 2014 10:43 pm
Care to say what power setting you were using? I've flown through light rain at about 2600 rpm (Prince P Tip on Aerovee) with no noticeable effect except the propeller being a little cleaner afterwards.
Re: Prince P Tip
Postby fastj22 » Sun Dec 21, 2014 10:51 pm
Care to say what power setting you were using? I've flown through light rain at about 2600 rpm (aerovee) with no noticeable effect except the propeller being a little cleaner afterwards.
We were running around 2600rpm too, economy cruise.
Re: Prince P Tip
Postby N111YX » Mon Dec 22, 2014 12:30 pm
When in the rain with my Sensenich I would use around 2400-2500 rpm where I normally run 2650-2850. One might be able to keep the paint on at the expense of not holding altitude.
Kip
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Re: Prince P Tip
Postby peter anson » Wed Dec 24, 2014 8:45 am
The P-tip prop that Prince recommend for the 3300 in a Sonex is a 54 x 60. I did 50 hours with mine but found it a bit too fine-pitched for cruising. Some figures are:
Full throttle static: 3000 rpm
Straight and level WOT: about 3350 rpm at about 140knots
Full throttle climb from take-off: 3000 to 3050 rpm
Cruise at 120 knots and 21 litres/hour: 2950 rpm
On a trip to a fly-in, a friend with a 3300 powered Sonex with 54 x 64 Sensenich prop had to slow up slightly for me. On the trip home he gradually left me behind. I think the 54 x 60 would be good for aerobatics, but I'm not rated. If you intend flying any distance I'd recommend a 62" pitch. I have just tried a 56 x 64 wood P-tip and it's too coarse. Damn.
Peter Anson
Sonex 894
Jab 3300, 180 hours
Re: Prince P Tip
Postby Doron » Wed Dec 24, 2014 1:26 pm
what is the Prince P Tip weight compared Sensenich prop ?
Doron
Doron
Re: Prince P Tip
Postby peter anson » Thu Dec 25, 2014 8:53 pm
Prince 54 x 60 mass = 2.82 kg or 6.22 pounds. Can't help with Sensenich info.
Re: Prince P Tip
Postby daleandee » Thu Dec 25, 2014 9:24 pm
Return to Jabiru
