intake couplers
intake couplers
Postby jwd3ca » Mon Jan 25, 2016 1:53 pm
Greetings... I'm thinking to replace my rubber intake couplers while I've got things apart, just wondered if anyone has found acceptable replacements. Thinking of 2" sections of 1.5" i.d. silicone hose, not sure if it would be gasoline resistant. For the couple of millimeters that are actually exposed to the fuel flow. Any ideas/suggestions? Thanks.
jwd3ca
Re: intake couplers
Postby fastj22 » Mon Jan 25, 2016 9:34 pm
Check Jeggs and Summit Racing. They carry silicon intake hoses of all sizes. I've replaced a couple on my Jabiru.
Re: intake couplers
Postby kmacht » Mon Jan 25, 2016 10:18 pm
Doesn't sonex sell the silicone ones? I remember an announcement about a year ago.
Re: intake couplers
Postby mike.smith » Mon Jan 25, 2016 11:05 pm
kmacht wrote:Doesn't sonex sell the silicone ones? I remember an announcement about a year ago.
Yes. I bought a pair and they work nicely. One does have to be very careful about the materials that will be in contact with fuel. Hoses may look alike, but may have very different compositions.
Re: intake couplers
Postby jwd3ca » Tue Jan 26, 2016 11:19 am
Sorry, Sonex sells the 2" sections that couple the intake runners from the manifold to the heads (six on a 3300)? I do find that Sonex's 'catalogue' of available separate bits and pieces leaves something to be desired...
jwd3ca
Re: intake couplers
Postby jwd3ca » Fri Feb 26, 2016 2:17 pm
Just a quick follow-up: I bought a 12" piece of 'heavy duty' straight radiator hose 1.25" i.d. at a local NAPA, about $10. Cut into 2" sections on my bandsaw. Perfect.
jwd3ca
Re: intake couplers
Postby Rynoth » Fri Feb 26, 2016 5:00 pm
jwd3ca wrote:Just a quick follow-up: I bought a 12" piece of 'heavy duty' straight radiator hose 1.25" i.d. at a local NAPA, about $10. Cut into 2" sections on my bandsaw. Perfect.
Careful, radiator hose is typically not fuel/oil resistant. The fuel/air mixture is likely to make short work of it if the material is not rated for fuel.
Re: intake couplers
Postby SonexN76ET » Fri Feb 26, 2016 5:42 pm
I agree with Ryan.
What will probably happen in using radiator hose that is not meant for carrying fuel is that it will start to crack and flake on the inner layers. These flakes of dried rubber will then flow into your combustion chamber and gum up your valves which will then lead to burnt valves which will then lead to broken valves which will then lead to blown cylinders. Then we will all read the NTSB report and shake our heads in wonder...
So is saving a couple of bucks on a cheap hose worth it?
Jake
Sarasota, Florida
SonexN76ET
Re: intake couplers
Postby kmacht » Fri Feb 26, 2016 8:51 pm
If you want to buy the same stuff sonex supplies in the kits it is fuel filler hose not radiator hose. It is the same hose that goes from the filler neck to your gas tank in the car. Napa sells it by the foot.
Re: intake couplers
Postby wolfpack3 » Sat Feb 27, 2016 12:32 pm
Amazon sells Gates 24702 filler neck hose. 1 3/8" ID x 36"
Worked perfect for me.
http://www.amazon.com/gp/product/B002H5 ... ge_o02_s00
Onex
Aerovee
wolfpack3
Return to Jabiru
