BenCharvet wrote:
In my installation the Aerocarb sits right behind the oil cooler. Has anyone made a deflector to direct that heat down and out and away from the Aerocarb/Aeroinjector? There is nothing left to insulate. Anyone else had a problem with the starter when it's hot? Next flight I'll check the temp on the Aerocarb right after shut-down. Sorry for the long post, but I know there is a lot of expertise on this forum, and I need some fresh ideas.
BenCharvet wrote: 9SX was finished in 2012 and had only 143 hours on it when I got it. The fuel system is very simple with a bulkhead AN elbow fitting going through the fuel flow sensor and a Jegs Fuel filter. A braided stainless fuel line enclosed in fire sleeve curves slightly downhill to the fuel inlet on the Aerocarb.
Users browsing this forum: No registered users and 19 guests
