by funflyingguy » Thu Oct 10, 2024 4:13 pm
hello all,
still learning alot about this sonex with the aerovee i bought a few months ago. mine has an under engine oil cooler, aeroinjector, straight dual exhausts, unrestricted oil breather tube venting underneath: pretty much stock. it was top overhauled 40 hours ago, with the scheduled maintenance done at 10 hours post overhaul by the previous owner and at 25 hours post overhaul by me. it has been dry as a bone in all ways except when the crankcase is full (2.75 qts).
i noticed right off the bat that it tended to blow oil out the breather when i had the crankcase full or near full (2.75 qts) until it got down to about 2.25 qts. it blew next to nothing from that oil level on down. not liking to lose oil, i decided to buy and install an oil-air separator that allows for capturing and recycling the oil back into the engine. it is modeled almost exactly after bryan cotton's efforts, having studied his pictures and followup posts. since this separator install, i have been losing lots of oil every time i fly the plane. in 3 short flights totaling maybe 1 hour, i lost nearly 24 ounces of oil. none came out the breather nor any of the new connections to capture and recycle the oil; all came out somewhere near the front of the cowling, soaked the right and left cowling halves and splattered all over the lower canopy. (i smelled it too...) at first i thought i blew a front seal or the oil pressure sending unit. but multiple, subsequent checks showed no oil from these places. so i disassembled the air-oil separator and removed the round, quarter-sized copper-like restrictor. the air flow was improved but not as free-flowing as the breather had been, which was unrestricted. i also checked the oil cooler lines and all were tight. went flying again and lost more oil from the same places, although not nearly as much. as best as i can tell right now, its the lower half of the engine, perhaps from the pushrod tubes, which are the spring type. i also monitored my MGL enigma for engine oil temperature and pressure during all this time. it has been showing normal pressures at all phases of flight, just slightly higher until the oil temperature warmed.
not having changed anything else except adding the oil-air separator, i am thinking a pressure or back-pressure issue. with the engine setup i have, what might be the first things to leak with high crankcase pressure?
