Excessive Shaft End Play
Posted: Fri May 10, 2024 10:25 am
Hello everyone - I am a new Sonex legacy owner as of 3 weeks ago. It has an Aerovee 2.1 (non-turbo) with 40 hours since new - the previous owner had this new engine built by an A&P. There have been a few minor issues that I have worked through but I believe I have come upon a larger one that I would appreciate some guidance on.
Last week I noticed some play in the drive shaft when I was repositioning the plane. I took a video https://youtube.com/shorts/yJZBBHb3Fj0?si=xlhzZVbRmB4PEpBH and sent it to tech support at Sonex. The response was this:
I assume he meant three shims minimum.
I did find this thread on the forum https://sonexbuilders.net/viewtopic.php?f=7&t=1556&hilit=shaft+end+play&start=30 from several years ago but none of the links are working any longer.
The engine has 40 hours on it. From what I have read in the above link and what I have been told from Sonex I believe my plan of action will be as follows.
1. Use a dial gauge to measure the current end play. Subtract .003" from that to determine how much more thickness in shims I will need to add.
2. Pull the engine off of the accessory plate.
3. Remove the gland nut. It sounds like this will take a considerable about of force. Should I remove the prop and attach a 2x4 so that I will have the leverage I need?
4. Measure the shims that are currently installed. Swap them for the correct combination of 3-5 shims for what I need.
5. Reverse the process.
Is there anything that I should watch out for that isn't in the installation manual?
How much time would you expect this to take a novice to complete? I do have decent mechanical sense and was able to successfully rebuild the font suspension of my 1980 MGB after watching numerous Youtube videos. That said - working on engines is all new to me.
Thank you for any help!
The link below is a video that deals with setting crankshaft end play along with page 17 in the manual. What I see in your video appears to be excessive.
The AeroVee manual calls out .006" as the maximum end play.
Normal end play is within .003 to .006 inches. End play is set by the number and thickness
of shims that are placed between the thrust bearing and flywheel. Three shims maximum.
