Oil pickup tube nut
Oil pickup tube nut
Postby Bryan Cotton » Fri Feb 16, 2024 11:05 pm
See that nut?
Inspecting that at annual it was several turns loose. I don't think I've looked closely at it before.
When I overhaul someday I'll figure out a better way to safety it.
Re: Oil pickup tube nut
Postby Area 51% » Sat Feb 17, 2024 7:55 am
Is the nut coming loose, or does the stud rotate in the case?
Double nut the stud from the bottom, and if you can turn it, it needs to be Locktited to the case. An annoying drip will ensue if those studs aren't sealed.
Postby Bryan Cotton » Sat Feb 17, 2024 10:03 am
We had debated which happened and guessed the nut moved based on the stud length sticking out the bottom. But, I'm not 100% sure.
Postby Bryan Cotton » Sat Feb 17, 2024 10:15 pm
Another forum member mentioned to me that he discovered that nut loose in the crankcase. We both looked for that step in the manual and he looked in the DVD. I think it comes preinstalled and there is no direction to check it during the build. I recommend checking it! Would probably be a good manual revision.
Postby pfhoeycfi » Sun Feb 18, 2024 9:15 am
I installed longer studs because the stock studs were too short to use with the mini sump. When I did that I made another single purpose pretzel wrench to grab the nut. I now check the nut whenever I pull the sump to clean the strainer.
Peter Hoey
Philadelphia Glider Council
Also built Sonerai IIL N86PH
pfhoeycfi
Postby Bryan Cotton » Sun Feb 18, 2024 9:47 am
pfhoeycfi wrote:When I did that I made another single purpose pretzel wrench to grab the nut.
Peter, I almost made one too, but Adam was able to use several different 10mm wrenches with different indexing to get it. It was a pain! I'd be interested to see a photo of your wrench posted here.
Postby pfhoeycfi » Sun Feb 18, 2024 10:06 am
I'll get one. That may be a good idea for a thread at some point, the crazy tools we make, or modify for a specific purpose.
Peter Hoey
pfhoeycfi
