Help troubleshooting potential causes of crankshaft failure
Posted: Fri Feb 16, 2024 12:23 pm
Hello!
As some of you may know I experienced an inflight crankshaft failure last fall with my older model AeroVee engine (not an AeroVee 2.1)
I was hoping to get some help assessing why this might have happened. Any theories are welcome and helpful. I'll try to provide as much information on the incident as possible.
About 2 hours into a flight I started experiencing minor vibrations. Adjusting mixture and running on either ignition made no change to the vibrations which within 2 minutes had increased linearly to the point that the instrument panel was unreadable. At this point the crankshaft broke at the front main seal, resulting in the entire propeller, spinner, and flange departing the plane (never to be found, lost somewhere in the woods of western NY). Luckily I had a long straight road underneath me to land on.
Facts about the plane: The plane (Sonex 0888) had been completed in 2007, it had remained in phase 1 flight testing until I completed it in 2023. Before I started flying the plane, the engine and airframe had around 30 hours. A condition inspection was performed by an A and P in 2023 right before I started phase 1 testing. The engine only had 1 hour on it since it's last condition inspection in 2019. I think it's very unlikely that the plane ever experienced a prop strike since the previous owner had done all of the phase 1 testing leading up to this point, and there was no damage history with the aircraft. When the crankshaft failure occurred, the engine and airframe had 101 hours. All of which I had flown since I bought the plane. I had torqued the prop bolts ~20 hours before the incident. One thing I had noticed previously was that the front main seal tended to weep oil over time. I didn't think this was anything major as it didn't seem like a significant amount of oil. The engine had plenty of oil before departing on the incident flight.
At one point I inquired to Sonex about the turbo upgrade kit. I found out this would require me to replace the current crankshaft with the AeroVee 2.1 crankshaft. Here's the response I got from Sonex:
"Also, we noticed an AeroVee serial number of 0303 listed for this order. This upgrade requires use of the AeroVee 2.1 crankshaft, which was supplied with AeroVee engines serial number 0435 and later. If you do not already have the AeroVee 2.1 crankshaft and prop hub assembly installed, you will need to upgrade for compatibility with the Turbo. This is most easily determined by the color of the prop hub: AeroVee 2.1 hubs are zinc plated (silver) whereas all previous AeroVee prop hubs have a black oxide finish (black in color). The AeroVee 2.1 crank also uses the ACV-H01-17 prop hub bushing and smaller ACV-Z01-74 bolt (M12 bolt vs. M20 bolt on older AeroVee prop hubs). You can see the current crankshaft and prop hub installation in the current versions of AeroVee manuals, downloadable at: http://www.aeroconversions.com/support/manuals.html "
Video of where crankshaft broke: https://drive.google.com/file/d/1TGO-6N ... sp=sharing
Pictures and closeups of where the crankshaft broke:
https://postimg.cc/gallery/Dwbw8TD
https://postimg.cc/gallery/nBwXgpj
Thank you all for your insights!
