pappas wrote:Peter,
After reviewing a couple of photos of my HDX in flight, I think your numbers are likely skewed to the low side. If they are accurate you are lucky indeed. I am looking at a photo of my HDX panel in my turbo with all the temps in the right places.
At 4500 ft (DA was 6502), OAT 75 deg f, 3330 rpm, 34.8 map, 151mph true, I was burning 8.1 gph. I generally ran at 2900-3000 rpm and 30 inches leaned for best CHT and saw a burn of just about 5.9 gph. I also used the aero injector and a 2.5 needle. I never saw the spectacular numbers that Sonex shows in Joe Norris' video of the turbo. Of course, they know their products better than I do.
An old rule of thumb for aircraft engines was to divide your engine's maximum rated horsepower by 11.5. The result gives you a fairly close approximation of the maximum fuel burn the engine should see at full power take-off on a standard day at sea level. I always found that number to be pretty close. 100 hp /11.5 = 8.69 gph full throttle. Too much more than that and you're Aeroinjector is likely not set up correctly.
I assume that you are verifying the reported fuel burn with actual measured burn numbers after several flights. If those numbers don't match then you need to adjust the K factor on the Red Cube. I usually get those dialed in after 8-10 flights.
I seem to remember that if you get jumpy readings, you may have an air bubble in the fuel cube. It is noted in the documentation that it has to do with the positioning of the cube and sharp downhill flows at the cube's exit side, but I never saw that in person.
pappas wrote:Peter,
Before you change the K factor on the Red Cube, fill up the tank, fly for a couple of hours, land, and top off the tank to see just how much fuel you actually burned. Compare that to what the red cube says you burned. The difference will tell you whether you need to increase or decrease the K factor. After a few flights, the red cube and the actual burn should be pretty close. That has been my routine for the last 4 airplanes I built and has worked well.
pfhoeycfi wrote:Below are graphs from my last flight, as seen in the Flight Data Viewer
XenosN42 wrote:pfhoeycfi wrote:Below are graphs from my last flight, as seen in the Flight Data Viewer
Reading your post gave me an idea. I'm sure you had to make a screen shot of the application and then cutout just the graph to create the JPEG file. The next version of the Flight Data Viewer will allow you to directly export any of the graphs as JPEG or PNG files.
