pfhoeycfi wrote:I removed the right side head to install timeserts to fix a stripped sparkplug thread. That was easy. Reinstalled the head. I've been trying now for two days to reconnect the exhaust manifold to the head. It took alot of effort to get the 2 forward bolts in and I'm struggling trying to get the 2 aft bolts in. There's got to be a trick that I don't know about. If I was starting from scratch I'd put slip couplings in this 4 into 1 exhaust pipe to make it easier to work on. Did that on my Sonerai way back. Anyone have any suggestions?
pappas wrote:I also had a lot of trouble with the AeroVee exhaust installation for the same reasons. Every time I had to remove the exhaust I dreaded it.
I came to the conclusion that the jig that was/is used to align the mounting flanges to the exhaust tubes for welding was not accurate. It was almost like the flanges needed to be clocked slightly. Maybe it has something to do with the different heads that Sonex has used over the years. Don't really know.
The best solution I could come up with was to remove the worst-aligned flange, grind it smooth, and re-weld it to fit correctly. They really don't fit well as delivered.
