Aero Shell 20W50 used in Areovee (non-turbo)
Postby Weatherpilot » Mon Oct 03, 2022 8:41 pm
Looking over the logs for my Aerovee on my new-to-me Sonex I see that the last couple of oil changes the previous owner serviced the engine with Aero Shell 20W50 oil. The reading I have done so far says we should use Valvoline VR-1 20W50 racing oil because it has zinc in it which is required for the VW based Aerovee motor. The previous owner just changed the oil before I got the airplane. Should I drain out the Aeroshell and start using the recommended oil?
Greg Hubert
Sonex A #972 TD
Third Owner
Weatherpilot
Re: Aero Shell 20W50 used in Areovee (non-turbo)
Postby mike.smith » Mon Oct 03, 2022 11:30 pm
My understanding is aviation oils should not be used in a VW. The explanation I have heard (so take it for what it's worth) is that the molecules in aviation oils are larger than in something like the VR-1, so don't pass through the system as they should. And yes, you need the zinc. I think Sonex recommends something other than the VR-1, now, but I've been using it successfully for 8 years, so I haven't seen a reason to stop. So yes, I would drain the oil and start with something that is recommended, with zinc.
Postby GraemeSmith » Tue Oct 04, 2022 7:29 am
Weatherpilot wrote:Looking over the logs for my Aerovee on my new-to-me Sonex I see that the last couple of oil changes the previous owner serviced the engine with Aero Shell 20W50 oil. The reading I have done so far says we should use Valvoline VR-1 20W50 racing oil because it has zinc in it which is required for the VW based Aerovee motor. The previous owner just changed the oil before I got the airplane. Should I drain out the Aeroshell and start using the recommended oil?
Absolutely change it - for the reasons Mike gives. Zinc on those tappets is vital and AeroShell does not have enough. The other recommended oil is Brad Penn Racing 1 20-50.
See page 60 of the manual:
http://www.aeroconversions.com/support/ ... Manual.pdf
Postby Bryan Cotton » Tue Oct 04, 2022 9:34 am
Aerovee Service bulletins:
http://www.aeroconversions.com/support/aerovee_sb.html
ACV-SB-091616-2A
Approved Oils
Revision A: Updated 02/26/2020 with specific oil brand recommendations
Approved Oil Specifications for AeroVee Engines have changed in-light of current oil industry research with modern oil formulations that prohibit the use of Full-Synthetic oils with leaded aviation fuel. Full-Synthetic oils listed as approved in previous revisions of AeroVee documentation (Valvoline VR-1, 20w50, synthetic and Mobil 1, 15W-50) are no longer approved. Note that Synthetic-Blend oils may still be used.
Approved Break-In Oils Are:
Valvoline VR-1, 20w50, non-synthetic
Brad Penn Penn-Grade 1 Racing 20w50 (Partially Synthetic: Recommended for AeroVee Turbo)
Approved Post-Break-in Oils Are:
Any questions should be directed to AeroConversions Technical Support staff at: tech@aeroconversions.com
Users browsing this forum: Google Adsense [Bot] and 12 guests
