Friesen5 wrote:Hi Graeme,
I’ve gone through quite a few oil pressure senders in my 500 hours of flying my Sonex. I then decided to use an electronic sender, with no moving parts.
https://www.aircraftspruce.ca/catalog/i ... ey=3758722
This continues to work well on my Sonex. Do some research to see if this might work for you.
Mervin Friesen
Sonex 122
GraemeSmith wrote:Ah ha.....
V 360-006 has the 10mm x 1 thread and a redundant extra pole for a warning light.
XenosN42 wrote:Friesen5 wrote:Hi Graeme,
Mervin Friesen
Sonex 122
I've also gone through too many VDO oil pressure senders. I'm seriously thinking about using the Swift electronic oil pressure sender you mention.
Which EFIS are you using? If you are using the MGL RDAC what, if any, DIP switches did you need to flip?
