Loose dipstick
Sat Jul 23, 2022 1:51 pm
Hey all,
My dipstick seems pretty loose. Is this normal? Should I worry about it coming off?
Re: Loose dipstick
Sat Jul 23, 2022 6:26 pm
by Area 51%
Wobble side-to-side is normal. If it's more than a light thumb-sucking fit, it will be fine.
Re: Loose dipstick
Sat Jul 23, 2022 6:37 pm
Gravity is holding it in place.
Re: Loose dipstick
Sun Jul 24, 2022 7:00 am
by Area 51%
I never trusted the Sonex supplied stick. Very difficult to get in and out without a trap door. I used a stock VW oil supply checker....remarked of course.
It did necessitate a hole in the cowl to let it pass, but was worlds easier to read.
As far as your stick is concerned, try replacing the O-ring.
Re: Loose dipstick
Sun Jul 24, 2022 9:36 am
Mine has no O ring. What size and where does it go? On the tube or in the cap?
Re: Loose dipstick
Sun Jul 24, 2022 9:41 am
by Area 51%
Inside the cap. Not a clue on the size. I'm sure Kerry has that information if you can get hold of him this close to the Fly-In.
I could dig mine out and check it if you can't get the scoop anywhere else. I'm sure I'll destroy it during removal, so if you just want me to send you the whole dipstick, PM me and I'll get it in the mail tomorrow.
Re: Loose dipstick
Sun Jul 24, 2022 11:02 am
Thanks Randy. I have one of those Harbor Freight oring kits, I'll mess around with them.
Re: Loose dipstick
Sun Jul 24, 2022 6:47 pm
I discovered the slot for the O ring in the cap. My O rings are too thick. I'm going to be at Oshkosh in a week and will see if I can get one there.
Re: Loose dipstick
Mon Jul 25, 2022 7:29 am
by Area 51%
Got the little "mother" out. Not easy to measure something as flexible as an O-ring with calipers, but here's what I came up with. And yes, I know the numbers don't quite add up; but what's an RCH among friends.
O.D.----------.442in 11.23mm
I.D.-----------.308in 7.84mm
thickness----.068in 1,72mm
Re: Loose dipstick
Mon Jul 25, 2022 8:54 am
Thanks Randy!
