Priming turbo cooler pump
Postby pfhoeycfi » Sat Mar 19, 2022 9:00 pm
My coolant pump won't prime and therefore I can't get the proper amount of coolant in the system. The piping is correct, the pump is running in the right direction and I tested the pump in the sink. I can put about 14 oz of coolant in... it it should take about 24. I was thinking of installing a tee in the suction line with a valve to try and fill it there while the pump is running rather than at the catch can. Any thoughts?
Peter Hoey
Philadelphia Glider Council
Also built Sonerai IIL N86PH
pfhoeycfi
Re: Priming turbo cooler pump
Postby pappas » Sun Mar 20, 2022 10:35 am
When I was doing mine, I noticed that the coolant radiator, placed according to plans, was actually slightly higher in the system than the coolant can. The result was that I could not purge the air from the radiator. I ended up filling the system from the highest hose coming off the radiator.
I also noticed that if the can is filled too high during the bleed process, you can not easily see the coolant moving through the can. I lowered the level to just above the cans return line and it was then clear that, although I thought there was no circulation happening, I could now clearly see the fluid moving.
It does not scream through the system like a class 5 rapid. It moves more slowly. Watch for tiny bubbles moving across the reservoir, not a giant current.
Lou Pappas
Phoenix, AZ
RV-7A Flying (2024)
Waiex B Turbo (2016)
RV-8 (2009)
Waiex Legacy 3300 (2007)
Hiperlight SNS-9 (1991)
Falcon Ultralight (1989)
pappas
Users browsing this forum: No registered users and 56 guests
