by Rynoth » Tue Dec 29, 2020 9:33 pm
I did a test flight today in my Aerovee Turbo with this topic in mind. I did a climb out at 85KT IAS starting from a field elevation of 1600', outside air temp 8C on the ground. I started my clock at 3000'. From there, it took 9 minutes to reach 8000' (555fpm average.) At 7000' is when I started to reduce power from 35" to 33" to keep CHT in check (below 400-420 CHT, oil temp wasn't an issue today, it maxed around 200F) during the climb. I leveled at 8000' to let things cool down. I then climbed from 8000' to 9500' and had to reduce power throughout to keep max CHT below 400, using about 28" MAP upon reaching 9500'. Once at 9500', 28" seemed to remain my best continuous power setting that kept max CHT (hottest cylinder) below 400, averaging around 380-400CHT. I did a ground speed check (4 cardinal headings reading groundspeed) which resulted in 118 TAS. I could easily push the power up to 35" but the CHT would quickly rise within 10-15 seconds and I'd need to bring power back down. I had power to continue a slow climb but do not have a transponder.
To sum it up, I need to work on my cooling. The turbo can make the power but my engine is just getting too warm.
One other topic that comes to mind in this discussion is boost pressure. At sea level, ambient air pressure is about 30 in/hg. At 10,000ft, ambient air pressure is about 20 in/hg. So, 40" Manifold pressure at sea level is basically 10 in/hg above ambient, whereas at 10,000ft 40" MAP is 20 in/hg above ambient. The turbo is definitely working harder (twice as hard?) at 10,000ft but seems to be up to the task. It may be mostly about cooling, but I'm sure some folks smarter than me could comment on other factors at play when boost pressure is doubled? Factors like compressed air temperature, cylinder wall pressure, etc.
