by pfhoeycfi » Sat Nov 14, 2020 9:47 am
I'm having alot of difficulty with the pushrods. For one I'm curious how best to get the tips in...simply heating and tapping with a soft mallet doesn't work and that's after spending slot of time cleaning up both the tip and tube. Im also wondering how many threads should be outside the adjusting nut on the rocker arm once adjusted with a feeler gage... I'm finding that having less than 1/32 difference in rod length is the difference between the adjusting screw all the way in (the nut backed all the way over the last thread) and on the other extreme not being able to back the screw out enough to get the feeler gage in. I've done a number of these over the years typically in a couple of days yet every step on this assembly has been a challenge. I thinking perhaps I may need to reconsider engine choice.
Peter Hoey
Philadelphia Glider Council
Also built Sonerai IIL N86PH
