Aerovee SkyTec starter switch intermittent connection
Postby Outlaw6 » Sun Sep 13, 2020 11:44 am
The starter switch wire connects to the SkyTec starter integrated starter solenoid. The connection is a 1/4" spade (Faston style) molded into a plastic connector that is mounted in a hole at the solenoid part on the starter. This plastic connector is loose in the mounting hole and has an intermittent connection inside somewhere, not sure if it's in the molded plastic or in the solenoid housing. I'm hoping someone knows what the internal connection looks like and if there is something internal that I can tighten. Is the plastic starter switch connection being loose in the case normal? Looks like there is an access plate for the solenoid that I may be able to remove without to much trouble.
Waiex N176WS (Tri-Gear Aerovee Turbo)
Outlaw6
Users browsing this forum: No registered users and 45 guests
