by pappas » Mon Aug 31, 2020 4:22 pm
I also went without a gascolator. I ran the fuel line from the firewall directly to the Aeroinjector. Firesleeve the fuel line, make sure it is routed as far from the exhaust as you can get it, and wrap the exhaust. Make sure that the Aeroinjector is the lowest point in the ful system.
These are just starting guidelines. Don't worry that the CHT's get to 280 deg f, Sonex gives us 420 or 425, (can't remember exactly), for 5 minutes! they will be hot until you get probably 50 hours on the engine in the air.
I also had problems with the engine dying after landing if I reduced the throttle too much with the mixture full rich. It worked itself out with additional hours, more familiarity on my part with the system, tweaking the mixture and idle settings with smaller and smaller adjustments, and landing with slightly lean mixture. Frustrating, I know, but you will get it.
Lou Pappas
Phoenix, AZ
RV-7A Flying (2024)
Waiex B Turbo (2016)
RV-8 (2009)
Waiex Legacy 3300 (2007)
Hiperlight SNS-9 (1991)
Falcon Ultralight (1989)
