by mike.smith » Fri Aug 14, 2020 5:32 pm
How many hours on the engine? Where is your oil temperature probe? In the sump? How is the oil pressure when the temps are displaying high? Is it a digital readout or a steam gauge?
Even with the top mounted cooler, Sonex still recommends (or they used to) getting air to flow through the cowl and under the oil sump.
I moved my cooler from bottom to top, but I left the smiley opening from the bottom mounted cooler setup. In the winter I have a plate to fully block the opening (it gets cold in the winter in Massachusetts). In the summer I either partially block the opening, or open it up fully to get air under the sump. I have never had any oil temperature issues.
There was a spirited conversation about this a while back, wondering if the lower oil temperature was because the probe was getting cool air, but the oil wasn't, really. I don't know the answer for sure, but I know that flying in 95 deg temps up here, and to and from OSH several times, I've never had any oil issues.
