Secondary Ignition Trigger Cap
Postby crahen » Fri Jul 24, 2020 8:20 am
Greetings,
Do you all recommend using a certain type of locktite when installing the trigger cap? I was thinking that a green or blue might be a good idea?
crahen
Re: Secondary Ignition Trigger Cap
Postby sonex1374 » Fri Jul 24, 2020 11:46 am
The trigger cap will be loosened and adjusted several times early in the life of your AeroVee while you fine-tune the secondary ignition timing. Loctite on the cap screw during this process may be more trouble than help. However, once you get the timing spot-on, a light-strength threadlocker might give a little extra assistance in keeping the screw from loosening. In practice, I don't think these screws tend to vibrate out on tier own, but strange things happen.
Jeff
Jeff Shultz
Sonex TD, 3300, AeroInjector
Kansas City, MO
http://www.sonex604.com
sonex1374
Postby crahen » Mon Jul 27, 2020 9:35 am
Thanks Jeff, that makes sense. It is right on the centerline and should have little vibration, but I think I may add just a small amount of green lcoktite for a little insurance.
crahen
Users browsing this forum: No registered users and 62 guests
