Rynoth wrote:It does sound like it's too lean, but you didn't mention adjustments to the needle position. What happens if you back the needle out a full turn? Remember that to enrichen the mixture at the needle you'd turn the hex screw counterclockwise.
Also are you making sure that when inserting the locking screw that the needle-carrier screw isn't also being turned? Visually check for any motion of the needle while inserting the set screw, and consider peening the needle screw threads slightly to make it more resistant to turning. If the locking screw is turning the needle screw during tightening it will be putting the needle into a leaner position.
Here is some more discussion on the topic of the needle and set screw:
http://sonexbuilders.net/viewtopic.php? ... rew#p40447
http://sonexbuilders.net/viewtopic.php? ... edle+screw
mike.smith wrote:A few questions: Where are the EGT probes located? Have you noted the CHTs? How long are you running the engine? Have you been able to note any colors of the exhaust?
gammaxy wrote:3100 rpm static sounds about right to me, so you're probably at least in the ballpark. Are you using the Sensenich 54x44?
As an additional sanity-check, did you notice whether the RPMs increased or decreased as you leaned the mixture? It's been a long time since I did the EGT test for tuning, but I do always get a fairly noticeable RPM increase when leaning from full rich on the ground at WOT.
The #2 needle tuned pretty close to the default position works pretty good for me. That you don't seem to be able to change mixture even with a needle change is surprising to me. In my experience, a single turn of the needle can change things drastically.
Have you performed a fuel flow test to verify your fuel system is not limiting you? I measured ~12GPH for the last 2 gallons in the tank. I've since removed the fuel flow sender from the line and suspect it flows much more now.
gethomas wrote:Running about 2-3 minutes at full throttle the will CHT go to 400deg. Some black smoke with #3 needle.
