by NWade » Tue May 12, 2020 9:37 pm
Chris -
Good on you for being careful! You should be sure to inspect every part in your AeroVee kit. A lot of us have found bad parts, or parts that didn't match up with what was in the instruction manual.
Usually the cause is a supplier to Sonex has either had a bad batch that snuck through that 3rd parties' QC, or they changed parts without telling Sonex staff, or the part was incorrectly packaged when it was sent to Sonex. I wish Sonex had better protocols (or manpower) when it comes to inspecting these items; but it seems to me that they get boxes/pallets of engine components in from 3rd parties, and just ship 'em out to customers without opening them.
Sonex airframe parts have always been of top quality and definitely well-checked and well-packaged before being shipped to me. Sadly the same level of attention-to-detail doesn't exist for the AeroConversions line of products.
It puts all of the onus on us customers to thoroughly check every item, and not accept parts as "OK" blindly. Sonex has always been reasonable with me about replacing parts (although I've occasionally had to nudge them or provide additional data to show why the item is a legitimate concern); but its happened enough that several folks here (including me) have some pent up frustration over it.
Keep that critical eye on your parts quality and follow the AeroVee assembly manual & videos, and you'll have a good engine you can be proud of in the end!
--Noel
Sonex #1339
AeroVee Turbo
(not quite flying, but a few hours of ground-run time already)
