by sonex1374 » Tue Mar 24, 2020 12:32 pm
I was recently speaking with a Sonex owner regarding a problem his AeroVee had developed recently where oil was leaking past the oil slinger and exiting the case by the prop hub. This has happened to several other AeroVee owners I know as well. In each case the problem has been a build up of excessive crank case pressure because the engine breather vent was not breathing properly. In this most recent case the breather tube was clogged with sticky goo (a mixture of oil, water and combustion byproducts that had congealed). Cleaning the breather tube solved the oil leak problem.
In some more extreme cases the engine required a larger breather vent tube, or even the addition of valve cover breather vents to be installed before the oil leak stopped. Something to think about if you have a similar problem.
One final thing was also not quite right about that installation was the placement of the air-oil separator. If using a separator, it's essential to place the unit in such a position that it runs hot enough to prevent large-scale condensation of water vapor inside the separator. This can be quite difficult to accomplish sometimes, and for that reason I'm not a big fan of separators on AeroVee's. Some engines will really need separators (Turbos, lots of aerobatics, documented history of pumping lots of oil out the breather), but on a normal-use engine, having a too-cool separator is worse than having no separator at all. In other words, if you're going to use one, you better do it right or not at all.
An alternative to using a separator is to simply use a catch bottle to accumulate and store the oil before it deposits itself onto the belly of the plane. This can be as fancy as you like, or as simple as an empty coke can safety wired to the outlet of the breather vent.
Jeff
