Rebuild Snag
Rebuild Snag
Postby n307tw » Fri Jan 31, 2020 6:58 pm
Hey guys!
Started rebuilding my ultra low time Aerovee to convert it (at the factory’s recommendation) from a 2002 to a 2.1 so I can utilize the turbo. The bore measured good on the cylinders so I opted to throw new rings in and reuse them. Got most of my parts from Sonex or CB performance, no eBay parts here!! However, the new piston rings I received from CB Performance did not meet Sonex specs. My ring end gap ranged from .005” to .007”. Manual states the gap should range from .012” - .022”. Since I didn’t have a ring filer and didn’t trust myself to make a square end on the rings with a hand file I decided to take them to a local machine shop. My question is for you guys that rebuilt, did you ever have too tight of a gap for the rings? What did you do to fix it? Did you decide to go the machine shop route as well or am I being too obsessive compulsive?
Tim Wrede
Long Island, NY
Sonex-B #18, Nosedragger
Aeromomentum AM15, Garmin G3X
My Build Site
n307tw
Re: Rebuild Snag
Postby lakespookie » Fri Jan 31, 2020 7:36 pm
I have built a few car engines but not a VW, Filing down the rings is ususally not a big deal. Like most things where you are removing material take your time and work your way to the size you need file a bit then check clearance again. Additionally since its a rebuild and you are using the same cylinders I would check the gap in multiple positions on the cylinder just to get warm fuzzies for the true of the cylinder. You should be more than familiar with deburring ;P.
Wiseco has a good blog post on the process http://blog.wiseco.com/how-to-file-fit- ... ston-rings
Jill's Build Log
PPL-ASEL
Tail = Complete
Wings = Complete
Waiex-B 0054
Panel G3X
lakespookie
Re: Rebuild Snag
Postby Bryan Cotton » Fri Jan 31, 2020 9:05 pm
I've always used a small file. Had to do a couple on the Aerovee, a couple on the Saturn, and a few more here and there over the years. No big deal.
